Butyl Caulk removal help
Discussion in 'Cosmetic' started by ResidentEvilRoc, Mar 21, 2012.
  1. ResidentEvilRoc
    ResidentEvilRoc Got bit by the HP bug.
    Rogersville, TN
    1973 Ford Maverick
    Recent pulled my windshield to begin on the cowl repair. Just wondering what is good to clean up all that sticky factory black caulk? Would Acetone be any good? Just needing to get it stripped and clean again. Man, that stuff gets everywhere!
  2. Dave B
    A screw driver and mineral spirits. Scrape as much off as you can...then clean it up with the spirits.
    There have been many posts over this nasty stuff over the years. :)
  3. rthomas771
    After dabbing it against it’s self to get the bulk I used gasoline and a rag. Acetone was too slow and too expensive.
  4. injectedmav
    injectedmav Member
    Georgia
    Brake clean, but it's expensive unless you get it in bulk.
  5. darren
    I used pro form air intake cleaner after pulling off the heavy stuff. It melts it off real fast. Dont get it on any plastic or paint though. I have cans and cans of the stuff. Very handy.
  6. Moneymaker 1
    Panama City Florida
    PB Blaster
  7. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Yet another use for WD40! I'd get one of the gallon cans and let it eat. Works great!
  8. ResidentEvilRoc
    Rogersville, TN
    1973 Ford Maverick
    Thanks for all the tips! Will be ripping it a new one this weekend, LOL.
  9. alex70mav
    alex70mav Member
    huntington beach
    1970 ford maverick 302
    break cleaner for everything!
  10. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    gasoline for everything!
  11. ResidentEvilRoc
    Rogersville, TN
    1973 Ford Maverick
    I found gasoline to work the best. I made a little "bucket" out of an old laundry detergent bottle. Then, you know all those paint brushes you have lying around that just quite didn't dry the way you wanted? The old super hard ones? I found a new use for them. First I would brush on a coat of gasoline and let is soak a minute or two. Then use a clean rag and just scrub and scrub. Works wonderful. As long as you use new rags every so often.
