Buying a 70 Maverick with 200
Discussion in 'New Members Forum' started by zman3003, Nov 1, 2010.
  1. zman3003
    zman3003 Member
    1970 maverick
    What type of work am I gonna have to do to swap a 302 into this car? Front end shocks springs?Engine mount? Tranny? Never swapped a engine before wondering if its worth it. The Car is in great Shape super chrome straight body nice paint just missing the rumble.
  2. don graham
    Engine frame mounts, motor mounts, headers, Radiator, Frame crossmember, tranny crossmember. Do a search for the v8 swap. There's lots of info there. :Welcome:
  3. zman3003
    zman3003 Member
    1970 maverick
    will the tranny work
    I have a 302 engine that runs well and Im not sure if I need a different Tranny or is the one from the 70 with the 200 compatable. what aobut shocks and springs
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  5. don graham
    The 200 tranny will bolt up behind a 302 if you get a new bellhousing. The question is how long it will last, unless it is rebuilt to take the abuse of the 302.:)
    I believe you'll also need to change the flexplate and maybe the torque convertor.
  6. mav1970
  7. maverick75
    I believe the 200 has the one piece TC/flexplate. So he would need a V8 flexplate and converter. Also be sure to use the correct flexplate. There are a few out there. You need to know what weight the motor was balanced to 28oz or 50oz. Also your bellhousing will determine the teeth needed.
  8. zman3003
    zman3003 Member
    1970 maverick
    Thanks for the input I have researched as much as possible at least the springs and shocks are the same from 200 of 70 to the 302 that was in the 71. A couple engine shops said the c4 thats in the car should be fine with the 302.
  9. Mercurycruizers
    Venetia, PA
    :Welcome:to the board...... I'm in the process of converting a 1970 Maverick 200 cu in to a 302 cu in also. I have a doner 74 Comet 302 cu in for the swap...
