c-4 pump gasket?
Discussion in 'Transmissions' started by 73rustymav, Jun 27, 2009.
  1. 73rustymav
    73rustymav Member
    clear lake, califorina
    First car in my life 69.5 maverick built 250 inline swap. 73 maverick RIP
    i need to know the procedures for replacing a pump gasket on a c-4. i have the pump pulled and cant figure it out because the 2 snap rings on the shaft.
    :hmmm:
  2. mean_maverick
    leave the snap rings alone. tap one of the holes that the bellhousing bolts use, screw a bolt into it, then attatch a slidehammer to the bolt and go at it. the seal will break and there you go....
  3. 73rustymav
    73rustymav Member
    i already replaced the seal... its the gasket behind the pump that i needed to fix. the worst part about it was all the guts came out after the pump and i had to put it all back in.... that took like 2 hours. but its done all i have left is to install my floor shift lever and the valve body. then its the process of installing a tranny:cry:.
