c-4 shift question
Discussion in 'Technical' started by maverick7072, Sep 11, 2014.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    at what speed does a c-4 shift down when coming to a stop mine shifts down around 35 mph seems kinda to fast for my taste ,also where is the best place to hook the modulator valve line.mine is attached TO THE CARB
  2. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    I'm guessing the speed would differ depending on your gears but it should ( far as I know ) be hooked to full manifold vac. So hooking to the carb is fine as long as its the lower vac port and not the upper timed one.
  3. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    well that might be my problem then.the hose is connected to the upper vac port! Can you plumb it to the intake itself?by the way I have 3.00 gears and 275-60 rear tires ,I just did a cam and intake swap and the intake I went to is the edelbrock performer and the previous one was the rpm intake I switched intakes because I need the rpm for another maverick and this car is more mild with a rv cam so the performer was a better match
  4. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Yeah you can run it off of the manifold. If memory serves the stock setup on the 2bl intakes had that crazy christmas tree vac dealio sticking off the back of the manifold and thats where the modulator got its vac from.
  5. Krazy Comet
    ALWAYS plumb the trans modulator into direct vacuum source... Every Ford factory setup I've seen used the intake, though there were some goofy dual setups with two vac ports that plumbed one line vac to ported vac... I always plugged that crap off and connected direct vac to modulator...
