C-4 to AOD lenth difference
Discussion in 'General Maverick/Comet' started by actionrpm, Jan 21, 2009.
  1. actionrpm
    actionrpm Differential specialist
    western pa.
    '70 mav. '40 Ford Pickup '72 Bronco '06 SuperDuty V-10
    Looked through all the posts,and tech. articles and could not find what I need,maybe some one like Paul,or other tranny guy might know.Building a full chassis Mav for a customer,and am fabbing engine mounts a X-member,(nothing is stock) I have an AOD behind a 302 for mockup and owner not sure if going to run a C-4 or AOD and want to build X-member to fit both trans.The AOD is 22 1/2" from back of block to center of studs on tailshaft mount,what is it on a C-4? The mount looks like it will interchange with a C-4,and I could mill slots in X-member if it's close....Thanks in advance for any help,Jack
  2. PaulS
    C4 from bellhousing to mount bolts is 20 1/2" (case fill)
    AOD from bellhousing to mount bolts is 22 5/16"
    I don't know what the difference in height might be though.
  3. actionrpm
    western pa.
    Thanks PaulS,I"ll just make a mount thats slotted and can be bolted 2" ahead,Thanks Jack
