c-4 to t-5 swap?
Discussion in 'Transmissions' started by 9psimustang, Nov 13, 2007.
  1. 9psimustang
    9psimustang Member
    ottawa canada
    77 maverick v8
    hey guys! my first post! i have a 77 with a c4 floor shift and a stall right now. what would it take to install a t5 tranny into this car? i have no pedal. it has 4 wheel power disc brakes. i would like to use cable or hydrualic setup if possible? how much grief is this swap? lol!! i assume the bell housing/starter is also different!:Welcome:
  2. PaulS
    The bell housing is different from all the earlier bell housings. I think the starter is the same though.
  3. 9psimustang
    9psimustang Member
    ottawa canada
    77 maverick v8
    thanks paul! i'm more concerned with the clutch pedal set up though!? any ideas?
  4. PaulS
    Well, I don't like cables - they stretch, break and never seem to have enough adjustment to make up for the problems. I don't like adding a master cylinder for either kind of hydraulic clutch. I know that there may not be any way to put in a manual linkage but that is what I would try first. If that couldn't be fit into use, then I would go with hydraulic using the hydraulic throw-out bearing.
    That is just me and my opinions. There are guys that can help with the cable set-up if that is what you want.
