I am doing a V 8 motor swap and i am wondering if the fly wheel from my Inline 6 will bolt up to 302 .can anybody tell me i need to do
What ever flywheel you have on your six - it will not work on a 302. All six cylinder flywheels and flexplates are made with zero counter-balance. All V-8s (unless you have a specialty build) are built with a positive counter-balance. Either 50 or 28 ounce depending on the year of your engine.
Cometguy, there is no couterbalance on a six cylinder flexplate. The 302 needs a counterbalance or tghe engine will vibrate worse than a Harley missing on one cylinder.
Your not looking very hard. You can get a new flexplate from Summit, Jeg's, Ebay and any local auto parts outlet. An early 70's v8 will have a 28oz balance. Small bell housing C4 will use a 157 tooth and large bell housing will use 164 tooth. Most likely you will needs a 157 tooth, 28 oz balance with a 10.5 inch bolt circle.
