c-4
Discussion in 'Transmissions' started by maverickmadness, Sep 7, 2010.
  1. maverickmadness
    maverickmadness Member
    ala
    1973 maverick grabber, 1972 maverick grabber,1974 maverick grabber,
    what will make a c-4 puke tranny fluid out the dip stick.?
    the fluid level is correct, and only pukes it at high rpm , 5500 to 6500.
    any suggestions on what it may be?
    thanks
    :hmmm:
  2. PaulS
    Plugged vent?
    Fluid too full causing air to get into it?
  3. maverickmadness
    ala
    i suspect the vent tube myself..havent had a cahnce to check anything as of yet , i do know the fluid level was correct at the time it started puking.:hmmm:
  4. PaulS
    With the fluid at the correct running level it is barely above the pan mounting surface. Something very strange would have to happen to get it to the level of the vent.
