c4 auto
Discussion in 'Transmissions' started by seth, Dec 7, 2008.
  1. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    ok i have a c4 with a column shifter what needs to be done to switch it to the floor?:16suspect
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    You can dig up all the stock linkages and shifter, and just do a complete transplant with donor parts.
    Or
    You can get an aftermarket cable shifter and do it the easy way.
    With a cable shifter, you just need a hole in the floor big enough for the cable to slip through. Also, with a cable shifter, you can mount the shifter anywhere within reach of the cable itself. Then if that cable isn't long enough to put it where you want it, just buy a longer one.;)
  3. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    thanks that sounds good
