...C4 dipstick and tube specs...
Discussion in 'Technical' started by 71gold, Jul 27, 2009.
  1. 71gold
    I have collected (5) C4 dipsticks w/tubes.
    2-are alike and don't fit.
    4- are different lengths
    there is 1 3/4" difference in where the full mark is on the stick between two of them.
    1- Craig... brought to me at the Roundup...it was like the one i had that wouldn't fit.
    1- i pulled from a C4 today, full mark 1 3/4" outside the tube.
    1-is a F.M.S. aftermarket...the full mark is 1 1/2" outside the tube.
    1- Harold pulled for me while i was out of town.
    none of the mounting tabs line up with a mounting bolt...:hmmm:
    3 have the full mark up inside the tube.
    is there any rhyme or reason to a C4 dipstick and tube?:huh:
    ...:bouncy:...
  2. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Nope... I've seen them all different lengths and marked.
    Just have to make sure you get one that is matched to the tube.
    Your best bet would be to order a new one. Maybe a nice flexible braided one that you can mount to the firewall or to the bellhousing. They dress things up nice and you will know it is correct.
    They don't show a picture but here is a link to it at your favorite store
    http://www.summitracing.com/parts/ADD-23-0003/
    Here is a picture... it's for a universal one
    http://www.summitracing.com/parts/MOR-25971/?image=large
  3. 71gold
    thanks Andy, but...
    I have an aftermarket one and as i stated, it's reading...1 1/2" deeper... than the pan rail. on a stock pan, that would be only half full. i don't think the pickup could get the fluid that low.
    ...:yup:...
  4. Andysutt
    Conway Arkansas
    1972 Comet GT
    Hrm... I misread the aftermarket one for some reason.
    Drain fluid, add the amount a C4 holds. check dipstick?
  5. 71gold
  6. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    Frank the ones that register up in the tube how long is the nipple on the end of the tube(from the flare where it stops at the caseto the bottom of the tube) are they all the same length there:?:
  7. 71gold
    do you have a source for this info. i have talked to 3 different transmission shops and got 3 different amounts. they say the size of my T.C. and aftermarket pan has to be factored in...:hmmm:
    ...Frank...
  8. Andysutt
    Conway Arkansas
    1972 Comet GT
  9. Andysutt
    Conway Arkansas
    1972 Comet GT
    Ask whoever you got the torque converter from, as well as the pan.
    If you can get the info on the converter, you can easily figure out the pan also by measuing it compared to a stock pan. Then take LxWxH of the extra pan depth and get the volume for this.
    The pan should be "X amount of quarts extra" so add that, and then add/subtract what your torque converter holds.
    Thats the best I can tell you... and I know you already know this information :tiphat:
    Do you also have the pickup for your transmission that goes down into the deeper pan? Some come w/ them, some don't. I've ran them both ways and had no problems but I preferred the extended pickup
  10. 71gold
    they are all the same at the installed point. it is the stick that is longer/shorter and the fact that none of the mounting tabs line up with a mounting bolt. the aftermarket one mounted to the head...:hmmm:
    ...:yup:...
  11. Andysutt
    Conway Arkansas
    1972 Comet GT
    Just a thought.... could the problem w/ it not mounting correctly have to do w/ having a big/small bellhousing?
  12. 71gold
    i have the extended pickup for the...1 qrt. over pan...i need the fluid cap. of a C4...:yup:
  13. Andysutt
    Conway Arkansas
    1972 Comet GT
  14. 71gold
    maybe...:hmmm:...
    Brand...TCI
    Manufacturer's Part Number...513310Part
    Type...Bellhousings
    Product Line...TCI Automatic Transmission Bellhousings
    Summit Racing Part Number...TCI-513310
    Bellhousing Depth...(in)6.250 in.
    Bellhousing Type...New
    Bellhousing Material...Aluminum
    Bellhousing Finish...Black
    Notes Fits case-filled transmissions with 164 tooth flexplate and a 11.4375 in. converter bolt pattern only.
  15. 71gold
