c4 fitment ?
Discussion in 'Transmissions' started by mavgrab302, Jul 19, 2011.
  1. mavgrab302
    Will a c4 that was on my 289 fit behind a 200 6cyl ? I will have the 6cyl trans if I need anything off it....
  2. shaneb
    shaneb Member
    Mckinney, Texas
    1973 ford maverick
    It should but more than likely you will need to change the bellhousing. Have you compared the two transmissions?
  3. mavgrab302
    I don't have them side by side yet, but I will have both the 6cyl and 8cyl trans to swap over what is needed... I was thinking swapping the bell would be all I would have to do... well maybe the converter too....
  4. don graham
    Probably the flexplate also. :)
  5. PaulS
    What year six and what cubic inch ?
    There are two sizes of input shafts - up to 1969 the C4 used a smaller input and uses a different converter. After 1970 the C4 uses a larger input shaft. If you want to use the small shaft C4 on a later engine you will have to use the early converter.
