C4 governor, how does it work?
Discussion in 'Transmissions' started by danford1, Oct 8, 2014.
  1. danford1
    danford1 Member
    White Lake, Michigan
    I have my C4 governor off and apart. I can see how centrifugal force will cause the bigger piston/valve to move and compress the spring. The smaller piston/valve has the spring on the inside which keeps the piston pushed out.
    Exactly how does the governor work?
    Thanks
    Danford1
