C4 Leaking
Discussion in 'Transmissions' started by Mr Nick, Oct 17, 2015.
  1. Mr Nick
    Mr Nick One with many questions
    Grapevine, Texas
    1971 Four-Door Maverick, 1962 Cadillac Sedan deVille (soon)
    My C4 seems to be leaking from right behind the bell housing. Any suggestions on how to go about this? Does the tranny have to be dropped in order to fix this? Or is it even fixable?
  2. Hotrock
    Munroe Falls, Ohio
    You need to be more specific. Pictures would help.
  3. 71gold
    be sure it's transmission fluid. if you remove the inspection plate is there fluid inside...front seal.
  4. Mr Nick
    Grapevine, Texas
    The bellhousing bowls out towards the engine block. Whenever it curves inward as it approaches the transmission main body, there appears to be fluid running from what I assume is where the bellhousing mounts to the transmission e.g not the rear main seal side of things so it's definitely red tranny fluid
  5. 71gold
    dipstick tube seal...shifter shaft seal...pan seal...:huh:
  6. Mr Nick
    Grapevine, Texas
    Oddly enough I switched all three of those seals.
    I looks like it flows straight down the middle of the bellhousing...
  7. Mr Nick
    Grapevine, Texas
    A lovely picture to help resolve this issue
  8. Mr Nick
    Grapevine, Texas
    Also, how much time is that gonna be?
    Should I take it to a shop to have it done, and, if so, how much would it cost if I brought them just the tranny? (Ballpark me here, already bought an overhaul kit)
  9. Mr Nick
    Grapevine, Texas
    Yikes, looks like it's back to the garage on that one
  10. 71gold
    should come from the inside of the bellhousing and drip from the bottom of the inspection plate if it's the front seal...:huh:
  11. Krazy Comet
    Bolts for bell housing to trans case may be loose and/or the gasket between pump and case is leaking... Pump is secured by the bell bolts I mentioned(at least if it's case fill) which AFIAK all Mav/Comet used...
  12. Mr Nick
    Grapevine, Texas
    So I have to pull the tranny, pull the torque converter out and then loosen the bolts from the bellhousing to the main body? At that point, I can replace the gasket that seals the bellhousing to main body and i'll be good to go?
  13. Mr Nick
    Grapevine, Texas
    That oil seal that surrounds the intermediate(?) shaft? But it rolls down the bellhousing from the back, not the front.
  14. Mr Nick
    Grapevine, Texas
    Also, any tips on how to re-install the tranny while the car is on the ground?
  15. 71gold
    make sure the converter is seated all the way in (three clicks) or 1/2 inch inside the lip of the bellhousing...
    don't pull the bellhousing up with the bolts.
