c4 or c6
Discussion in 'Technical' started by HOMERMAV, Nov 2, 2008.
  1. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    what trans should i put in my 71 mav behind a 89 302 mildly built
    thanks john
  2. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    If you have to choose between the 2 definately the c-4, but if you can swing it an AOD would be better. The c-6 is big and will rob you of HP especially in a mildly built motor, without the benefit of overdrive. C-4s are cheaper to build and properly built will handle all the HP a mild motor can have.
  3. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    I'm not positive a c6 will fit under there w/o some modifying..
    But a C4 is plenty for a Maverick
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    What's the application (daily driver? strip only? street/strip?)?
    I think a C6 is too big/heavy for either street or strip. AOD's are nice for streeters (as we all know from 71Gold) but would require a few mods.
    C4 for strip only.
    IMHO
  5. Andysutt
    Conway Arkansas
    1972 Comet GT
    Are you meaning to put a C4 in it if its only for the strip?
    Because a C6 won't fit so he's either going to use a C4, AOD or a Manual
  6. Rick Book
    Rick Book Member
    Thailand
    Yes, C4 and 4XX gears for strip only small block (specific gear would depend on if running 1/8th mile or 1/4 mile and what diameter tire will be uesd), or a C4 and 2XX or low 3XX gears for highway only. Or an AOD with 4XX gears for a street/strip application or street-only application (again, the specific gear would depend on what size tire is being used).
    The 4-5 speed is okay for strip but not likely to be as consitant.
    Unless it's a big block, the C6 is really too heavy for the application (and probably too big as you mentioned - I dunno for sure tho).
    These are just my own personal preferences. Your (and many others) mileage may vary.
  7. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    well, I afta not disagree with you :thumbs2:
  8. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Heck, I'd even run a C4 with a 460... They got bells for that. Ford even made some C4 bells with the BBF pattern.
