c4 problems
Discussion in 'Transmissions' started by chromed302, Jan 6, 2014.
  1. chromed302
    chromed302 Member
    78 mustang cobra ll
    c4 upshift problems
    Hopefully someone can help me out, I have a 77 c4 case filled green stripe modulator and what its doing is... I can put it in park, neutral, reverse and drive and it does just fine but when I put it in drive its stuck in low gear(1st) and doesn't shift and it wont shift manually from 1st to 2nd to drive just stays in that low gear(1st) I been told to check governor and vacuum modulator and the psi on it I put a new modulator in it and I have it running to a vacuum tree on my intake and the valves in the governor move freely what else I can check out? Thanks!
  2. 71gold
    is the...kick down rod...moving freely/hooked up?
  3. chromed302
    chromed302 Member
    78 mustang cobra ll
    I'm not running the kick down i hear some say its not really useful you can use it if you want if not it wont hurt anything?
  4. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    When installing the valve body it is possible to get the kickdown lever in the wrong position causing this problem. The lever outside the trans could be bound up on something in the applied position.
  5. chromed302
    chromed302 Member
    78 mustang cobra ll
    well right now I have it tore down I took tail shaft off and took off the governor to check the valves make sure they weren't stuck then I took vb out to check make sure maybe the 1-2 shift valves weren't stuck(haven't been able to take vb apart to check that yet) I've been reading articles about this would the forward clutch spring or the parking pawl have anything to do with my problem?
