C4 to a 5 speed swap
Discussion in 'Technical' started by streetrod77, Dec 2, 2004.
  1. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Has anyone swap a C4 to a 5 speed. How hard is it? Dark Horse Performace has kits to swap early Mustangs to 5 speeds. Are the frame or cross members the same as Mustangs. Please help, thanks
    www.darkhorseperformance.com
  2. Mavaholic
    The crossmembers are not the same and will not work without modification. It would be easier to modify the one you got. The hardest thing to find will be clutch linkage. If you got the bucks, you can go with a hydraulic set up. The Mustang kits will work here. If you have good fabrication skills, you might be able to modify the clutch pedal for a cable set up.Then all you need is a clutch pedal set up. After that, Its the standard stuff like bellhousing, flywheel, and clutch parts.
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    There is always the dude on eBay that sells the instructions and parts list necessary to do this swap .... $10 ....
  4. Fearmont80
    Fearmont80 Member
    Burbank,IL
    Hehehe....just bought one off that guy earlier tonight just to see what its all about.........only $10.....I`l probably post the results on here if anyone wants.
  5. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    I'm interested...very interested!
  6. Earl Branham
    Lugoff, SC
    I am considering this, and the instructions and parts list would be helpfull!
  7. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
    I got the book last week. this is all from the book
    Parts list:
    Clutch & brake pedals out of a 68 mustang
    mustang clutch quadrant kit (comes with quadrant, cable)
    Cable adjuster
    brale pedal pin (from Automatic car)
    5/16 tap
    t-5 tranny, bellhousing, flywheel out of a fox chassis mustang (preferably 91 & later due to stronger tranny.)
    You may need to shorten youe drive shaft, check to make sure b4 bolting everthing together.
    he also shows you how to fabricat a trans crossmember and a few other things you'll need
  8. Fearmont80
    Fearmont80 Member
    Burbank,IL
    Blown76Mav.....I`m trying your technique as we speak....just happened to have a Fox-Body pedal assembly laying around.......and an autmatic Maverick assembly that came with the car extra..........I took the manual pedals out of the car before I started for comparism sake.So far I got all the pieces needed off the Mustang setup,the tube and all,just got back on here to print out your directions to help me with the rest.
  9. Fearmont80
    Fearmont80 Member
    Burbank,IL
    Well I guess I wasted $10 on Ebay......I just finished the pedal setup.It only took a couple hours to do,its great to have everything on hand to do it.I had to shorten the clutch pedal about one inch and weld the pad back into place.Tack welded the tube into place too.I used a hole saw to cut the hole.Actually,I used a couple smaller bits,upto a 1/2" bit at first and then realized I didn`t have a 3/4" bit needed to drill the hole big enough......so I thought I screwed myself....but I noticed that the only difference between the stock auto and manual setups was the pin that holds the pedals in,I switched them,and was able to use the manual setup/brake pedal with the fox-body clutch pedal so I didn`t have to modify the brake pedal.I should have used the pad off of the Maverick clutch pedal so it`d look more stock,but I can still change it if I want too.
    But anyways,thanks Blown76 for the directions,it worked great!!! Now that I know how to do this....and I`m not working...hmmmm.....anyone else need a setup????
  10. Fearmont80
    Fearmont80 Member
    Burbank,IL
    Heres the pictures!
  11. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I'm still looking for parts before I can tackle this. This don't seem to be as bad as I thought.
  12. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    Would anything be any different for using a Tremec from Ford Racing? When the time comes, I don't think a stock mustang will hold up for me. It might, but I'd rather only do the whole "buying/installing a tranny" thing once, if you know what I mean. Thanks ya'll!! Preston
  13. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    The T5 & one of the Tremec's are alike for the most part but I can't remember witch one. The one that comes in the 88-93 Mustang is the one that handles more torque. I thought all of them could be built up. But not sure.
  14. Country Mav
    Evans, Louisiana
    I see where you are coming from. The only reason I was asking is that the motor I am building will (hopefully) be putting out a bit over 600 hp. (This is undershooting it) It will NOT be a daily driver, only a show/strip car. Since it won't be driven all that often, it won't be stressed on a regular basis. But I will say that when I do drive it, it will be severely tested. I drive hard, so I will try to build accordingly. That's why I was thinking of the Tremec. No real other reason other than they are supposedly stronger. I know the T-5 will handle a lot of power (as is apparent with your car ;) ) but I just feel like a Tremec would provide me with a little more peace of mind. :D Ya'll take care, Preston
  15. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I dont even remember this thread. Its been 2 years & I just now have most of the parts. Time sure goes fast. What is a cross tube? Do I use the mustang break pedel? Its the same size as the clutch pedal or do I keep the stock maverick pedal?
