C4 to AOD swap part #'s
Discussion in 'Transmissions' started by Stavro, Jul 25, 2010.
  1. Stavro
    Petaluma, California
    1972 GRABBER ZRX1200r
    I'm doing the swap from the C4 to the AOD. There have been members here that have done this swap and NONE of them have given any part numbers(that I can find) for the CORRECT flexplate and the CORRECT cable and related brackets.
    Who has the numbers and can post them so we don't have to do all this rediculous homework every time someone wants to do the swap?
    If I knew all the numbers I'd post them all so anyone that was curious knew for sure what they were up against.
  2. 71gold
    I did a search and found this...
    AOD question ...Pioneer FRA-205 flywheel
    Frank...
  3. Stavro
    Thanks for the link to the part number thread. I never would have found it.
    Hey, in that thread, the guy asked if it was difficult to adjust. Is it?
    Is there a Ford number?
  4. 71gold
    what Ford # are you asking about?
    the adjustment is simple...(y)
  5. Stavro
    For the flexplate....or did Ford never offer the option. 'They' say it's a flexplate out of a 'newer'(whatever that means)TBird or truck w/302 or 351c and a C4....but no part numbers.
  6. 71gold
    a search gave me this...
    Automatic Flexplate Fra-205 Ford Lincoln Mercury 73-88
    Frank
  7. Stavro
    Ok, so here's what's needed for the swap:
    TV/TC bracket - SRK- 4000 -
    Throttle Cable
    -TC1000U
    TV Cable - KD-2AODHT - (Holley Carb.)
    TV Cable Corrector
    - Sum-700202
    Drumroll please......
    The flexplate is.......
    NAPA PART #600-5012
    164 TEETH W/28oz weight
    Plus whatever the yoke part number is
    (some have said they didn't need the AOD yoke)
  8. Stavro
    TV Cable Corrector - Sum-700202
    comes up as:
    Throttle Valve Corrector, for Holley Carburetors, Buick, Chevy, Oldsmobile, Pontiac, 700R4, 200-4R, 4L60
    Is that correct?
  9. PaulS
    There are two lengths of AODs and there are two outside diameter yokes for the AOD. This is why some people tell you they used their original driveline with no problem and others tell you they had to shorten the driveline and use a different yoke. The splines on the output shaft are the same - just the OD changes depending on the original year and application.
    Since I don't deal with installations I don't keep a database of the different years and models specific applications - I am more concerned with what I do on the inside of the AOD to make it strong enough for a given application. I want it to be strong enough to live a long and happy life under the conditions of operation.
