C4 to t5 swap question
Discussion in 'Transmissions' started by Banta, Mar 17, 2015.
  1. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    I was looking at putting in a t5 when I drop my 302 in my 72 comet. My question is exactly what all will I need? I found a cheap s10 with a t5 and was wondering what all parts I can rob off it for my setup. And I'm on a tight budget at the moment so I will try to avoid the high dollar stuff. Don't need it to be race ready yet. Thanks in advance :cheers2:
  2. krelboyne
    krelboyne Remember
    Salem, Oregon
    I believe that you would only want a T5 transmission from a Fox body Mustang. Preferably 1989-1993, and only from a V8 5.0L Google is your friend, been done many times on vintage Ford cars, especially Mustangs.
    http://moderndriveline.com/Technical_Bits/transmission_spec.htm
    Tons of information on the modern driveline website.
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    If you want to find a reasonable T5 find one from a late 90's V6 Mustang, they are cheap and will bolt to the 302. It has the same rating as the mid/late 80's GT and will hold up fine behind a stock V8. You will need the larger flywheel which you can get from a truck and the clutch setup from the V6 Mustang. The clutch linkage will need to be worked out, the T/O bearing arm is lower than the Fox but it shouldn't be too difficult. I paid $150 for mine and it had less than 90k on it.
    Banta likes this.
  4. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
    Thanks. That helps alot
  5. Banta
    Banta frankincomet
    madison indiana
    72 Mercury comet
