C4 TorqCvt' from Six for a V8?
Discussion in 'General Maverick/Comet' started by Powerband, Jul 2, 2016.
  1. Powerband
    Powerband Member
    NY's \H/
    Does a 76 Mav C4 - Torque Converter work for a SBF 157Tooth V8 C4 bell?.
    Friend is building an early Mudstang and needs a TC for the 289/C4 . I have a C4 out of a 76 Maverick 200 Six and offered the TC if it will fit. I never learned to drive automatic tranny cars so only build 3 pedal cars and have no use for it.
    have fun
    Not a slushbox
  2. Krazy Comet
    The 200 will likely have a smaller flexplate and torque converter(my '71 did)...
    No matter what engine, C4 torque converters won't swap from '70/later to '69/earlier...
  3. Powerband
    Powerband Member
    NY's \H/
    why ? ...
    oddly enuff. the '76 has aC8DE 200 and a small bellhouse C4.
  4. Krazy Comet
    The input shafts changed from 24 spline to 26 beginning '70..
    AFAIK all 200 trans from '70s have small bell... I believe some 200 used in Fox bodies were of the larger 250/302 size...
  5. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    The starter gear is part of the TC for the 200 six . Not so with the V8's - part of the flex-plate.
    PS: Re-builders are running short of the 200 TC. You may be able to get some $$ for it.
  6. Powerband
    Powerband Member
    NY's \H/
    > thanks for the tip, I hate to get rid of anything having reasonable use-ability. Usually with other enthusiasts , I'm just swapping parts for a small fee.
    haev fun
