C4 Trans Buying info?
Discussion in 'Technical' started by Jap901, Jan 11, 2006.
  1. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
  2. fredee
    fredee Member
    South MS.
    1971 comet
    Sorry can't answer your question but I have been looking at this guy also. How about Broader Performance anybody ever used them?
  3. mavman
    mavman Member
    Arkansas
    Why not build your own? The C4 is really easy to work with...very simple. A rebuild kit is what, $80 now? Last kit I bought was $45....seals, gaskets, clutches, steels, and seal rings.
  4. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    That guy is just down the road from me. I've often wondered about the quality of his tranny's. Do it yourself, cheap and easy!!
  5. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
    Ok I'll try to rebuild myself. I will get the video and book. Also I have a few Questions.
    What special tools are needed to do a rebuild?
    whats it take to install 5 clutch pack?
    what are the best performance clutchs?
    Are there any other performance upgrades that should be done in the rebuild?
    Thanks Jim
  6. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
    Hello thanks for the replys. The maverick will probly never see a drag stip but i do what the trans to hold if i deside to.
    It will have a 3000rpm stall and 4.11 rear gears, The desktop dyno shows 420hp & 390tq so I am hoping to get 350hp.
    thanks Jim
  7. CometGT1974
    Western NC
    74 Comet GT
    You need to visit this site for info.....best c4 site in the web.
    http://www.fordmuscle.com/phpBB/viewforum.php?forum=13
    Make yourself a list of questions and then spend some time on this forum searching for the answers. You will learn everything you ever wanted to know about the c4 and some things you didn't want to know!!(y)
  8. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    Myself, I am going to buy a TCI Sizzler transmission from Summt, run in the $550 range.
  9. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    Where would I find a book showing how to build a C4.
  10. CometGT1974
    Western NC
    74 Comet GT
    I would just buy an ATSG service manual off of ebay. Or from www.atsg.biz
  11. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
    Thanks there is a lot of info on this forum.(y)
  12. Cleaver
    Cleaver Member
    MD
    Chel
    I get my parts from Makco Distributing.
    If you do it yourself I suggest getting a thrust washer assortment kit. This is how you set the endplay. You can re-use them but endplay always end up different - probably because I've always had to mix and match parts from different transmissions. The only special tool you need is a spring compression tool to change the O ring behind the pressure plate on the forward drum. I've made one out of a piece of 2-1/2 inch exhaust tubing and a vice that works.
    Cleaver
  13. scooper77515
    A 3000 stall and 4.11 and no drag strip???
    Let me guess, just long-distance, cross-country highway driving :p
  14. sierra grabber
    sierra grabber Certifiable
    northern nevada
    xpsnake, I heard bad things about the TCI trannies. i was going to use their kit to rebuild the c-6 in my highboy and there was a lot of negs on it on the web and amongst my pro mechanic friends and family members. I bought the more expensive PA c-4 for my car, havent run it yet though. it had a lifetime warranty up to 450 horses so i figured i should be G2G. just a heads up.
  15. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    The only thing from tci i ever used didnt work worth a crap!! A super street fighter torque converter that was supposed to be a 3500 was actually 2000.
