C4 Transmission Doesnt Shift to Third!!
Discussion in 'Transmissions' started by mustangman66, Aug 18, 2011.
  1. mustangman66
    mustangman66 New Member
    Mustang
    I have a 66 c4 green dot that refuses to engage third gear. Ive replaced the modulator, oil and adjusted everything but i still have no progress. Its rather frustrating and id like to know if anyone had any idea what this could be. Thanks so much for your help.
  2. mustangman66
    Mustang
    So it could be the gasket between the carb spacer and the intake log?
  3. 71gold
    check for a split in the modulator vac. line.
    i also had one that the vac. line had become soft and was collasping shut under vac.
    ...:tiphat:...
  4. mustangman66
    Mustang
    Actually the hose connecting the steel line to the modulator is a soft one that seems easy to push in. Is it supposed to be a stiffer, thicker hose?
  5. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
  6. mustangman66
    Mustang
    That is precisely what it looks like. So could it be the deteriorating line connecting intake manifold to the steel line? It is rather burnt up but im getting a pretty good vacuum reading at the manifold. Somewhere in the 19's and 20's
  7. mustangman66
    Mustang
    Is there a way i could check if the transmission would shift to third otherwise?
  8. whitey68
    whitey68 Member
    springfield illinois
    71 comet gt 65xxx orig miles .. 69 mercury marquis 2dr hard top land yaught, 62xxx orig 2 owner 429 4bbl 2000 heritage softail
    check your kick down, make sure it returns back up when you push it down
  9. mustangman66
    Mustang
    Checked the kick down and it definitely returns.
  10. PaulS
    Check the vacuum at the modulator - it has to be 10 or above.
    Could be a bad hose at either end of the metal line or a cracked line to the modulator.
    If you have reverse then it might be a stck 2-3 shift valve if the vacuum is above 10 at the modulator.
    It would help to know what speeds the transmission shifts from 1 to 2 also.
    Paul
  11. KauaiHi
    KauaiHi Member
    1975 Mercury Comet 5.0 V8 2bbl (4door)
    where is the vaccuum mod hose?
  12. PaulS
    It connects to the modulator located at the passenger (right) rear corner of the main case - just above the trans pan. Test it there with the engine idling in park.
    It should connect to the manifold vacuum either at the rear of the carb mount on the manifold or the vacuum tree on the firewall.
