C4 Transmission
Discussion in 'Transmissions' started by J.M.HUDSON, Jul 19, 2015.
  1. J.M.HUDSON
    J.M.HUDSON New Member
    1970 MUSTANG
    My C4 Transmission hits hard when I put it in reverse, sounds like the rear end is breaking loose, I have new U-Joints, can I fix it without pulling out the transmission?
  2. Rasit
    Rasit Member
    SE Pennsylvania
    Could be a sticking valve in the valve body which would not require removing the tranny.
  3. 71gold
    :Welcome:...:Handshake:
    may I ask, is this for the car in your sig?
  4. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
  5. Paul Masson
    1971 Grabber
    :Welcome: from Atlantic Canada!! I would also check the rear pinion for play/leakage around the seal. A bad pinion bearing in the rearend will also give you a noticeable clunk.
  6. mav1970
    :Welcome: from Northeastern Pennsylvania
