c4
Discussion in 'Transmissions' started by Boosha, Mar 30, 2010.
  1. Boosha
    Boosha Built to run hard
    Buckeye State
    69.5 Maverick,1964.5 Mustang,1966 T-Bird
    72 c4 been sitting for about 4-5 years.Was fine before I pulled it,and has been wrapped up in the corner of the garage since.Other than a fluid/filter and seal change,What are the chances that it's still ok?
  2. PaulS
    well, there are two ways to be sure what the condition is:
    1. complete tear-down inspection (might as well rebuild it since it is apart anyway)
    2. Install it, fill it let it sit with 4 quarts of oil in it for at least 20 minutes and then start it up and finish filling it with the engine idling in Park. Use type "F" fluid only.
