c5 help
Discussion in 'Transmissions' started by classic ccg, Oct 22, 2014.
  1. classic ccg
    ringgold GA
    72 maverick
    i got a c5 that i was told it was a c5 so i want to know two things
    one what is the wires coming from the trany?
    two what is the top leaver for?
  2. yellow75
    Tillamook Oregon
    The wires are for the neural safety switch and back up lights and the lever is for the kick down linkage
  3. baddad457
    The difference between the C4 and C5 is the C5 has a lockup converter and a deeper bell housing (longer) to accommodate the lockup converter.
  4. classic ccg
    ringgold GA
    72 maverick
    So will the c4 crossmember work? And how do I bypass the neural safety switch the wires we not hooked to it
  5. baddad457
    Yes, as long as you can get the bolt holes lined up. The C5 is about an inch longer than a C4. Might have a problem with the driveshaft though, you'll have to get everything in then see how that fits.
