c5 wont engage...more oil?
Discussion in 'Transmissions' started by Mavber70, Jun 4, 2013.
  1. Mavber70
    Mavber70 Member
    Oshtemo,Michigan
    1970 Maverick Grabber
    hi guys,so I installed a c5 with a deep pan dumped 7 quarts of oil in it and it wont engage.Does it need more oil?The dip stick shows its over full but I sat there for a while playing with it and it seens like the oil is just sitting in the oil pan cause I drained some and the oil is cool like just out of the bottle.
  2. Krazy Comet
    If the level is over full and doesn't drop when the engine is started it isn't pumping... Did you add fluid to the converter prior to install???
  3. Mavber70
    Mavber70 Member
    Oshtemo,Michigan
    no I didn't since I seen it had some already but not sure how much..
  4. Bryant
    7 quarts is not enough. its hard to say how much you do need sense you dont know how much is in the converter.
    are you sure the dip stick shows full vs just getting wet from atf on the dipstick tube when its being inserted and pulled out?
  5. Mavber70
    Mavber70 Member
    Oshtemo,Michigan
    I check it in park over and over and its way over the full line....maybe like 1 quart on the converter id say
  6. Mavber70
    Mavber70 Member
    Oshtemo,Michigan
    yes the engine is running hot.
  7. groberts101
    groberts101 Member
    Minneapolis, MN
    9 quarts seems a bit much for a C4 that has had fluid in it already.. but it has been a while since I've filled either a fresh one or done an oil change on one.. and a +2 qt deep sump pan might put you near that amount. Be sure to also run it through the gears to completely fill the valvebody and clutches with oil.
    If you didn't sufficiently prefill the TC.. the pump may not self prime and the unit will run dry. Which is never a good thing for the pump and internals.
    Was this unit rebuilt?(completely dry).. or just swapped over to this motor after a pan/filter change?(partial fill)
  8. Mavber70
    Mavber70 Member
    Oshtemo,Michigan
    has 2 passes on rebuilt
  9. Krazy Comet
    I'm thinking the pump may be air locked so isn't pulling the fluid into the converter, even if there isn't enough fluid in the pan to fill the converter the level should drop to below the add... Maybe if it sets awhile it'll be OK...
    Next time you start it if the fluid doesn't drop shut it off and wait longer, like over night then try again...
  10. Mavber70
    Mavber70 Member
    Oshtemo,Michigan
    if not,then I would have to pull the trans and fill the converter?
  11. Mavber70
    Mavber70 Member
    Oshtemo,Michigan
    I let it set for like a week and still nothing,i disconnect one of the lines and they have oil going thru...so imam just pull it back out and recheck everything and fill the converter.When I changed the bellhousing the pump came forward but I but it back carefully so not sure.
    :hmmm:
  12. Krazy Comet
    If the oil is circulating through the cooler lines the pump is working, you have other problems...
  13. Mavman72
    Did you get the converter in properly...It has to engage the dogs on the pump gear. If not, you have damaged the pump and or converter...Pull the trans back out and double check it...
  14. Mavber70
    Mavber70 Member
    Oshtemo,Michigan
    yes I did I hit first bump then kept turning it slowly till it hit the second bump,i had no problems with the install
  15. Mavber70
    Mavber70 Member
    Oshtemo,Michigan
    yes im going to pull it and reinstall carefully
