Caltrac experiment.
Discussion in 'General Maverick/Comet' started by scooper77515, Mar 30, 2014.
  1. scooper77515
    For those of you who know my history, I have dealt with a drone in my car since I dualled out the exhaust, not just with flowmasters, but with side pipes and glasspaks under the car.
    I recently put in a x-pipe and much of that drone is gone. Now while I am driving at highway speeds, I can hear the engine just purring, but there is still a physically-felt, mechanical feeling vibration wave that I would like to work out. Mild, my wife doesn't notice it unless I point it out, but I can feel it, and am pretty sure it is affecting my u-joints. (all the typical culprits have been worked out...new tailshaft housing, new trans and motor mounts, professionally balanced shaft, new joints, etc)
    I have caltracs that i run at 1-1/2 turns preload, and up until this past week, I had 2 degree shims to adjust pinion angle. With that setup, the vibe was pretty bad, and pretty loud, and I could even feel it pulling down my engine while it reached its crescendo. Especially when I accelerated and further loaded the leafsprings (further adding pinion angle).
    Friday, i took off the shims, and took a 90 mile round trip yesterday, and it was WAY nicer.
    Today, I backed off all the preload, and turned the caltracs 4 turns off the spring, basically removing them completely. I am hoping that there is enough slack that the springs will never touch them and make noise, for the time being.
    My hypothesis is that I am now back to stock suspension except for the 4th leaf, and I may have the pinion angle back to stock, and I should lose the rest of that vibe.
    Taking a 60 mile round trip today...will let you know.
    If this works, I will keep it like this and only put about half that preload on only when I take it to the track (which is RARELY). I live near the Royal Purple 1/4 mile track now, so maybe I will get more chance to run it in the near future.
    But I also don't want to hear the springs slapping the loose caltracs, and would rather hear the slight vibe instead.
  2. John Holden
    John Holden Member
    NJ
    you can also slip a piece of rubber hose over the shaft that contacts the springs.
  3. scooper77515
    Well...made it worse. Going to add preload a quarter turn at a time and see what happens.
    But first a crawfish and shrimp boil with family!
  4. Dave B
    Have you read the instructions? 1 1/2 turns seems like a lot for the street.
  5. 71gold
    mine were 1/2 turn of preload and road rough...:yup:
  6. scooper77515
    Well, I turned it 1/4 on and it helped a bit.
    I will put another quarter on it and try again.
    When it is not vibrating, it sure is quiet on the inside. Still loud on the outside, though!
  7. Dave B
    The round spinny thing, sits about a 1/8" off my spring, and I put some rubber hose around it, I kinda like the sound, but I really like how the car raises when you get on it.
