Cam and heads?
Discussion in 'Technical' started by HarleyGA, Aug 1, 2012.
  1. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    What cam/carb/heads/pistons is your 302 running?
  2. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    its in the bottom of my sig :)
  3. junrai
    junrai Member
    rancho cordova ca
    I have an extreme energy comp cam I forget most of the specs but it has a 512 lift and the heads are stock with the exception of new springs to go with the cam
    otherwise engine is stock
  4. Streamliner
    Streamliner Member
    Don't know the cam but AFR heads
  5. DC12VOLT
    DC12VOLT Fuel Injected
    Everett, WA
    Cream 1971 Maverick
    The motor I'm building is running:
    -This cam: Duration 262/272, Lift .448/.472
    -No carburetor; A ported '87 Thunderbird HO intake manifold with multiport fuel injection does the same job.
    -Ported C9TE stock Ford truck heads
    -Stock 1968 302 cast pistons (I believe)
    This is an extremely budget-oriented build, and should still provide quite a bit of oomph.
  6. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    AFR 185's ported and polished, Comp Cams .614/.621 Solid Roller Camshaft, Probe Race Series dome pistons 13-13.5 comp ratio, Quick Fuels Technology E85 Race Carb.
    302 based (8.2 deck height) Man O War block with 347 stroker crank/rods
  7. Red1972Grabber
    Northern California
    Lunati Bracket Master II cam 284/284 duration .488/.488 lift advanced 4 degrees
    Holley 770dp Street Avenger carburetor
    Stock heads (valve jobbed and exhausts ported)
    Keith Black hypereutectic pistons
  8. baddad457
    Everything but the SRP pistons ins listed below.
  9. dgrenfell
    dgrenfell Danny
    Michigan
    73 maverick 63falcon
    Mines all old school 289 30 over trw .200 dome pistons 69 4V 351 Windsor heads boss 302 D0ZX cam .568 lift with 1.6 rockers 324 dur shelby 2x4 intake with 2 660 cfm carbs at this time
  10. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Since you asked about 302s and not 347s
    I will tell you my old combo...
    9.2 to 1 compression with A Ford racing
    X-303 hyd roller cam. .545/.545 lift
    224/224 dur. @ .050.
    Offenhauser tunnel RAM with 2-450 Holleys
    drove it anywhere ,anytime I wanted,great street manners
    And would run 12.45 @ 109 on pep boys radials and 12.20 @112 on slicks
    Any time you wanted.
  11. scooper77515
    Those are some pretty stout setups! Makes mine look wimpy! I thought mine was a bit hard to drive on the streets!
    Details in my sig below...Custom ground cam, so I don't know all the specs. It was originally ground for a fox-body mustang, running a heavily nitroused 5.0. I got it as a hand-me-down, and made the rest of the valvetrain work with it.
  12. beecj0
    beecj0 New Member
    alaska
    306 ford
    Come on guys! dont let the thread drop that easy.
    My 306
    Iron gt40s fully ported ss valves, comp 990 outer 975 iner springs, cobra 1.7 rockers
    vic jr intake, 800 dbl pmper
    moddifide fox body 1-5/8 bbk equal shortys
    Old trw 11.3 pistons, pollished chamber and piston top let me run 91 oct. cool clean alaska air helps too.
    555 in/549 ex, 236/244 @.050, 108 lobe sep, 104 intake centerline.
    Idles at 850rpms all day,
    ran a best of 11.82@113.7mph with a s#!t 2600 stall torque converter that has 24.7% slipage bogging till the tail lights pass the tree!
    just orderd a new 4000 tci. All the math comes out to a 11.35 @123 if all goes well in my 2700# ride!
  13. Krazy Comet
    There is no such thing as a HO 5.0 SEFI intake in a pre '91 Bird/Coug... The lowers are same but upper has a smaller throttle body opening...
    The 5.0 in the Comet is bone stock, but I have a Trick Flow headed and cammed 5.0 in a '88 T-Bird... Also has Cobra intake, 65mm throttle body, 1 5/8" shorty headers, full 2.5" exhaust system...
  14. junrai
    junrai Member
    rancho cordova ca
    my 302 has stock iron heads with an edelbrock air gap intake my cam is a comp extreme energy with a 512 lift I dont remember the duration but the rest of the engine is stock except the lifters and valve springs to go with the cam and headers
    Im upgrading my engine to a 347 stroker with all forged internals and aluminum comp heads the 1.7 roller rockers were said to bring my cam lift up to I think the machine shop said a 544 lift.
  15. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    347ci forged crank h-beams and pistons 12:1 comp .Trickflow track max stage 3 cam .574/.595,AFR 205 Outlaw race heads ported/polished and O-ringed by lynn morris. Vic jr and quickfuel E85 carb.Runs like a raped ape
