cam suggestions??
Discussion in 'General Maverick/Comet' started by starsky74, Apr 23, 2009.
  1. starsky74
    starsky74 Technician
    Hackberry Louisiana
    ok heres my set up, what im wanting to know is what cam everyone recommends. 92 cougar 5.0 HO stock rotating assy, gt40p heads, airgap intake, 600 holley, 2500 stall converter and b&m street shift kit oh i also have 1.6 erson rollers too
  2. PaulS
    With a 2500 stall you are going to be limited to about 214 degrees at .050" lift for duration and I don't think I would go over .5" lift with those heads.
    The extreme energy cams are great but you may need valve train mods.
  3. starsky74
    Hackberry Louisiana
    it may be a 2800 stall
  4. PaulS
    If you haven't opened the shift kit yet send it back and get a TransGo 40-2 reprogramming kit. They have no known problems - like the B&M kit does) and it will make the C4 come alive! You will think you have gained 25 hp!
  5. plovett
    plovett Member
    Kansas City
    Don't have one yet
    What rear gear ratio are you running?
    paulie
  6. starsky74
    Hackberry Louisiana
    paul s, i was really considering that. How much do those kits run?
    plovette, currently the stock 3.0 8inch but very soon to be 8.8 3.55
  7. plovett
    plovett Member
    Kansas City
    Don't have one yet
    I think you can run a little more duration with the 3.55's. I would say something like the Ford E303 would work well. It's not an ultra modern, aggressive lobe profile, but then like Paul said you might not want to go lift crazy with the factory heads.
    http://store.summitracing.com/partdetail.asp?part=FMS-M-6250-E303&autoview=sku
    I like the tighter 110 degree lobe separation with this cam. Most 5.0 hydraulic rollers have a 112-114+ lobe separation angles to work with fuel injection. The 110 will work better with your carbureted motor IMO. It will sound much better too if that matters.
    That said, this cam has .498" lift and I don't know what if any valvetrain mods you might need.
    JMO,
    paulie
  8. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
  9. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
  10. plovett
    plovett Member
    Kansas City
    Don't have one yet
    so what you gonna' do Starsky?
    paulie
  11. PaulS
    You can find them on-line for a bit less than $70 sometimes but the usual selling price is about $100. I don't know what the B&M kit sells for but I do know that a lot of people have had problems with them in the C4. TransGo has great customer support too - if you have any questions you can call the number in their kit and get answers to any questions you have.
