Cam ?
Discussion in 'Technical' started by stangman99, Sep 2, 2002.
  1. stangman99
    stangman99 Member
    Colorado Springs
    74 Maverick
    I have 74 Maverick stock 302 freshened up motor, I have a set of twisted wedge alum heads with FMS roller rockers, should I replace the cam is my question If so what, I also have Edelbrock Performer & Edelbrock spreadbore 600cfm carb, & headers to put on. Later on down the road I am planning on a 347 stroker for the heads!
    Any help please!
    Im In new territory here havent been racing In 30 + years!
    Thanks!
    Yes I do want to put the heads on this 302 now!
  2. EFIMAV
    EFIMAV Member
    Davenport Iowa
    Change cams
    call the head manufacturer and ask them to give you a good idea of the type of cam to use. Use those heads to their potential. A retrofit roller would be nice!
  3. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    Another thing to be answered is the valve to piston clearence with those kind of heads on any combo, if you go high on lift. On a stock 302 with dish pistons there won't be a problem but with flat tops there could be, so be awhere.
    Depending on how long you will run the present engine, a low priced cam like an RV type will give you a good boost in torque to play with until you go to a roller 347. Staying with the flat tappet cam block is ok but there is more power in the roller block.
  4. Thack
    Thack vision advicator
    Moreno Valley Ca
    I thought one of the selling points of the twisted wedge heads was rotated valves so you can have large valves and higher lift without flycutting the pistons......................
  5. stangman99
    stangman99 Member
    Colorado Springs
    74 Maverick
    Just got the old heads off today I hear talk about fly cut, well these pistons look like they are? Looks like , , only sideways?
    Never have had a Ford small block apart so I dont know??? Looks to me maybe 1/4" or less deep:confused:
    Thanks for you replys!:D
  6. 74merc
    74merc computer nerd
    1974 Comet
    Is it a performer or performer RPM?
    The Edel Performer will limit you.
    just a generic cam to throw in there, Comp Cams 270H would be a little better than stock, shouldn't be limited by your intake too bad either.
