can 4dr door hinge be used on 2 dr?
Discussion in 'Technical' started by maverick7072, Oct 22, 2013.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    i need a bottom hinge for my 70 will the hinges from a 4 door interchange with the 2 door cars?thanks!
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    Yes, they can. There all the same.
  3. 71gold
    ...:yup:...
  4. Craig Selvey
    Where the hinge bolts to the car takes 3 bolts. Where the hinge bolts to the door I have seen 2 bolt and 3 bolt versions. Even with that....I think they are interchangeable.
  5. rthomas771
    The rear bottom door hinges on a 4-door are different than the front door hinges. The front door hinges are the same on both 2 and 4-door
  6. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    thanks everyone that's what I needed to know
  7. neil dodson
    neil dodson Member
    Orange Va.
    1970 maverick
    Door hinge attaching plate
    Hi yall;
    Speaking of door hinges, how do you retrieve the plate that is in the frame after it falls from the place it was? Once I removed the bottom hinge to install new bushings and pins, the threaded plate inside the frame that the hinges bolt to fell to the bottom! Is this normal? What is the easiest way to put it back where it goes? Thanks guys.
  8. rthomas771
    Remove the kick panel and put the plate back where it goes.
  9. neil dodson
    neil dodson Member
    Orange Va.
    1970 maverick
    Thanks for the response. I have to admit, I feel kind of stupid. Once I removed the kick panel and saw the access hole, it was like, "DUH"! There it is! PLenty of room for my big hands. I'm sure I will have lots more dumb questions for you guys as this project progresses.
