Can Anyone Answer This?
Discussion in 'Technical' started by Vamdab, Jun 16, 2005.
  1. Vamdab
    Vamdab New Member
    Near Hershey, Pa.
    !972 Maverick Grabber, Fully Loaded! RARE!
    Someone just might have my answer!
    Hi... my name is "Vamdab" and I have a 1972 Ford Maverick Grabber, With a Nasty 302, and a T10 Side loader (Built nice) W/a Hurst in-line 4 speed shifter. The Bell is actualy the Original one that came in the car. My Problem is, Nobody makes headers for a manual trans. So I still run manifolds and don't get everything that my motor has to offer. I need a Clutch set up to turn the manual "Z" bar setup into a hydraulic system so that I can run headers. Even if I could use headers with the Original, I would still like to get rid of it! It jumps out alot, Leaving me with no clutch. Thanks for your time! I hope Someone can give some good news.
    Hershey, Pa.
  2. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    I used Hooker 6901's. I am running a 302 with a toploader and manual z-bar. They fit great, no mods.
    JP
  3. bmcdaniel
    Hmmm, Vamdab. BadMav backwards. Several companies make headers for manual trans Mavs with the mechanical linkage. The clearance problems occur when you try to use a column shifter. Doesn't sound like you have that situation. I never had a problem with anything "jumping out". Something must not be installed correctly.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
  5. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Hooker 6901's work fine with the factory z-bar setup .. lots of us here on the board use them ... including me ...
  6. grbmaverickmo
    Aquashicola, PA
    6901`s on mine fit well with zbar . Good to see another mav not to far from me.
  7. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Yeah me ditto on headers and 4gear.
    Dan
  8. Mavaholic
    Count me in for the same set up. At one time I had a T10 and it takes less room than the toploader.
  9. Mavaholic
    Yup, what Dan said.
