Can get it Loose - C4 trans removal
Discussion in 'Technical' started by 72Comet35, Feb 28, 2010.
  1. 72Comet35
    72Comet35 New Member
    Azusa, Ca
    COMET
    I pulled my 302 with a C4 and i took off the starter off and the 6 bolts that attach the bell and it will not pull off. its loose and has a 2 in or so gap but will not pull free. .. any advise? please help
  2. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    I did that with my old Fury. That 727 just wouldn't let go.
  3. PaulS
    Pull the converter nuts - there are four of them. Sometimes the alignment studs get stuck and you have to pry them apart.
  4. 72Comet35
    Azusa, Ca
    COMET
    ok cool thanks ill try that tomorrow morning.. any other ideas?
  5. starsky74
    starsky74 Technician
    Hackberry Louisiana
    converter nuts.
  6. 71gold
    if the transmission is back...2"...i wouldn't think the studs are the problem.
    ...:huh:...
  7. justin has a 74
    kentucky
    rookie!:D
    i hope that trans is drained!
  8. yellow75
    Tillamook Oregon
    Inspection cover plate is holding it on
  9. 72Comet35
    Azusa, Ca
    COMET
    thanks guys i know im a rookie but i got it off...
  10. Bob Wiken
    Fayetteville, Arkansas
    What was holding it?
  11. 72Comet35
    Azusa, Ca
    COMET
    well im a dam fool.. there was another small plate on the bottom that had 2 bolts in it i didnt see because it was on the ground i didnt see them... thanks for the help
  12. yellow75
    Tillamook Oregon
    Yep been there done that :)
