Can H.O. forged pistons be used in a 1968 block?
Discussion in 'General Maverick/Comet' started by Eddie Maverick, Dec 31, 2007.
  1. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    I have a 68 302 block, and a buddy dumped a set of forged TRW's out of his 88 H.O. since he's building a stroker. Could I use these in place of the cast pistons that were in the block? He gave me the pistons with the rods as well.
    If I can use them, what needs to be done?
    Thanks
  2. wagesofsin
    wagesofsin Official Lurkologist
    sarasota, florida
    74 challenger , 73 'cuda , 72 challenger , 74 barracuda
    a slugs a slug.as far as material is concerned. just check the clearances and other particulars, or you may have some ummm...... issues..
  3. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    thanks for the reply.
    What about the rods? Can I use the rods that are on the H.O. pistons, or do I have to put the forged pistons on the old rods?
    Are the rods the same?
  4. wagesofsin
    sarasota, florida
    cant help ya on that one . if they are the same journal diameter and length, i would see no reason they would not work. have your machinist do a comparison on both. he should be able to tell you.
  5. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    If they are the same length, etc as mentioned earlier then you shouldn't have a problem at all.
  6. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    well I posted this on Ford Muscle as well, and found a guy that is doing the EXACT same thing. How lucky did I get on that one. Anyway, I have to use the rods from the '68 with the H.O. pistons and all will be good. I just have to make sure my piston to wall clearance is within spec of .004 -.006 IIRC PaulS actually answered that question for the guy on FM.
    Thanks for the replys guys
  7. Andysutt
    Conway Arkansas
    1972 Comet GT
    Just exactly why the rods matter?
    If they are exact same rods you wouldn't have to swap anything out.
  8. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Rods are the same...
  9. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    hmmm.... really? well in that case, the swap will be a lot easier. Maybe the uy that used his old rods didn't have the rods from the forged pistons. The easier the better for me. so If the rods are the same i'll use them.
    Everyone is certain the rods are the same?
  10. 19BlacK77
    19BlacK77 Member
    You could just find you a junkyard 5.0 (since it has the roller cam) and just build it. You might as well get a little more power while your at it and another motor shouldnt cost over $250.
  11. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    yeah i explored that, but I have this block, so I'm just gonna deal with this one, plus I already have the dogbone,spider setup to convert this block to roller if I wanted to.
  12. ratio411
    ratio411 Member
    Pensacola
    While you have the rods out, it's always a good idea to put aftermarket bolts.
    The regular ARPs don't cost much, and the stockers are a known weak link.
    You'll need to run a dingleberry hone on the block, assuming it doesn't need boring, so the new rings will seat.
  13. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    yeah I will be ordering the bolts for the reassembly, and just bought the hone tool for the job. The bore is good so I should be good to go.
    I got a 351 cam from a swap meet for a buck brand new, I don't have the specs here with me right now(i'm outta town) but when I looked it up it was a clevite replacement for a bronco truck.
    So i guess it would be like a RV cam in this block. I might use it if I don't do the roller conversion.
  14. tim keck
    sharps chapel,Tn
    My buddy blew up his original '85 5.0 GT,the rod had a C8 cast # on it,I'd say they(rods) are all the same.
  15. bmcdaniel
    If you replace the rod bolts the rod's big ends will have to be honed, you can't just press in the new bolts and run 'em.
