Can I remove an engine with the driveshaft still on?
Discussion in 'Technical' started by maver!ck, Jan 29, 2012.
  1. maver!ck
    maver!ck The Maverick Guy.
    Colton
    69.5 Mav, 5.0T
    Wife's engine threw a rod and took out the block.
    One of my neighbors has a 302/C4 that he's willing to give to me if I pull it out.
    Only issue is that the rear of the car in sunk into the ground, cant acces the driveshaft at all. It did have some room to get in and cut off the transmission crossmember.
    But that's as far as I can get, is it possible to just pull out the engine straight forward? will it slide out of the slip yoke I mean.
    The whole front end of the car has been chopped off so that's a plus.
  2. mercgt73
    Yes, it should slip out and spill ATF all over the ground for you.
    What about the speedo cable?
  3. maver!ck
    Colton
    69.5 Mav, 5.0T
    thanks, i think I can just cut off the speedo cable, I alrady cut the shifter linkage off.
    (y)
  4. baddad457
    :mg::biglaugh::taz: quick, someone call the EPA !!!!:outtahere:
  5. darren
    LOL. Good one. Yep its gonna make a hell of a mess coming out.:yup:
  6. Dave B
    I'd love to watch.....
  7. blugene
    If it's coming out a Mav cut the floors out if they are good. Then you could save that crossmember AND have some floors to use/sell IF they are any good. Could also cut the shaft and keep that yoke pluged in.. Just a thought..
  8. baddad457
    :biglaugh: And it seems no matter how hard you try to prevent ATF from coming out of an transmission, somehow, it ALWAYS does. I've cleaned up more than my share of ATF and motor oil from the driveway and shop floor. :huh:
  9. Tannersg1
    Tannersg1 Member
    Classified
    Post some pics!!!!!
  10. mavgrab302
    I used a small tarp spread out to catch the mess.....
  11. Pony Express
    Pony Express Haul'in @**
    DelMarVa
    1976 Maverick
    What about finding someone with a tractor, truck or semi-tractor to yank it out of the ground, so you can effectively do your work?
    I had a simiilar scenario, used my cousin's semi-tractor after disconnecting the trailer; you would never have known the car was mired as easy as it came out...
  12. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Oh, amen to that brother! I am convinced there is not even a marginally clean way to do anything to a transmission. Every single time I touch one I come out from under the car looking like I was just pumped out of the ground by an oil rig.
  13. maver!ck
    Colton
    69.5 Mav, 5.0T
    I live in the inner city, not much farms around here .
    thanks for the help guys, the tranny ended up being dry.
    boy having the front end not there really helped a ton
