I was wondering if anyone knew how to take out the window crank and inner door handle without messing anything up.
Just stripped both my doors today to start getting ready to paint.Peel the round sticker out of the center of the handle,remove philips srew in handle,there are (2) 3/8" head bolts in the armrest,unscew and arm rest and surround mld. will come with it.CAREFULLY pry the trim panel off,(theres tool for it) a wide scaper will work,there are pop off clips about every 6".The fiber board wants to break apart if old so go slow.Once you get the trim panel off there are 5 bolts that hold regulator in,unbolt and slide the regulator all the way to one side then the other and it will slide out of the track,the window will then come out of the door,then then the regulator,I had to remove one door felt for the window track to clear but I'm replaceing anyway.
