can someone identify this part on the side of the cylinder head?
Discussion in 'Technical' started by russellgaspard, Jul 7, 2014.
  1. russellgaspard
    russellgaspard Member
    united states
    1973 Ford Maverick 250 Inline 6
    I need a new one. Could someone tell me what the part with the white label is called? I need the entire thing thats screwed into the side of the cylinder head.
    (added more photos)
  2. rthomas771
    Hard to tell from that angle...maybe the heater hose fitting?
  3. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    It's the heater hose fitting.
  4. russellgaspard
    united states
    i looked for a heater hose fitting but I cant find anything that looks the same. If this piece is more than one part could someone please give more info on it. It looks to me like it might be three separate parts. The square middle and then two parts that screw into that. I need them and dont know where to start because I dont know what they are called.
  5. m in sc
    m in sc Member
    rock hill sc
    those are all NPT threads 3/8th if i remember. its a tee and spigots. nothing particularly special, you can use brass fittings to replace them, mccmaster carr is prob your best online non oem bet.
  6. russellgaspard
    united states
    I tried looking on the site you said and cant find anything. The site is confusing to navigate and im not completely sure what to look for. I dont mean to be a bother but could you be more specific?
  7. Krazy Comet
    That's no doubt factory, has opening for the vacuum switch that was on the middish '70s models...
  8. rthomas771
    You are correct that it is 3 pieces. Each piece needs to be remove before you can unscrew the Tee from the head or the fittings will hit the cylinder head. When I went with a header on my 250, I had to use a straight pipe for header clearance. Do you live where they do emissions? If not then you can use a straight hose fitting and do away with the vacuum switch and vacuum hoses. In all probability the vacuum switch stopped working 30 something years ago anyway and its not doing any good now.
  9. Craig Selvey
