Can someone sell me 3.80 or similar gears? (or trade)
Discussion in 'Technical' started by scooper77515, May 5, 2005.
  1. scooper77515
    I need 3.80 or similar, may go as low as 3.5 or as high as 4.11, for Ford 8" rear. I currently have 2.79, great for highway use, crap for strip. Would trade or buy your gears for decent price/deal. I also have some parts left over from other Mav projects, I would be willing to trade.
    Or, could you recommend where to find cheap gears.
    I am going to try them, and may not like them, and don't want to pay full price for something I might yank back out and replace.
  2. scooper77515
    Come on guys...I see 11 views so far, but no replies. Where can I buy used or cheap gears? Hi-Lo drew a blank. I guess their books don't cross-reference that low of a gear with Mavericks.
  3. Craig Selvey
    What you are looking for can't be bought "cheap".
  4. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Try www.ringpinion.com
    I don't know of a source for used gears. I would be cautious
    about using used gears.
    Seth
  5. scooper77515
    So all prices are about the same, $179-$229?
  6. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
  7. scooper77515
    Autokrafters used parts has several 3.70 center sections for $200. Isn't that the entire yoke, ring, pinion assembly? It would be nice to have a 3.70 and a 2.79 to swap out as needed.
  8. 71gold
    scooper,
    if you would, see if they have a 3.55 for me. thanks (y) ...frank...:bouncy:
  9. scooper77515
    I will write myself a note and try to remember when he calls me back. Is that 8"?
  10. 71gold
    :yup: ,
    ...frank...:bouncy:
  11. rx7351w
    rx7351w Member
    knoxville, tn
    74 2 door Maverick
    I looked for a while (6-8 months) and gave up. I bought new 4.11 locally for $200 and tax.
  12. scooper77515
    rx, how is your 4.11 set up, and how is it working? What size tires, and do you use it highway at all? What are RPMs at 70, approx?
  13. scooper77515
    Frank, that was a 9" he had at Autokrafters. He only had 2.79, 3.00, and 3.25 for 8". How would 3.25 be on the track. Sounds more like a highway gear. Would I see much better improvements going from 2.79 to 3.25, or would I still be too slow off the line?
  14. scooper77515
    Approx what RPM would 3.25 and 245/60r15 tires give me at 70mph?
  15. Earl Branham
    Lugoff, SC
    I have a 3.00 gear, and I run 3,000 rpm at 70 mph. Not good for racing, but about 20mpg on the highway.
