fiberglass it. It appears that you broke off one of the mounting tabs on your rear spoiler...is that what is in the picture? try to fiberglass or epoxy it back on, or, for a more permanent fix, fiberglass the entire thing to the trunk for a no-line look (that is what I will do before I paint). Also, there is one for sale on ebay right now...
yes it is my rear spoiler, it was loose on one end so I took it off. luckly the stud and boss was in the trunck in a bag with the retaining cup and nut.
may have the fix I think what I will do is remove the stud from the boss. then use the boss as a guide to drill a hole in the main part of the spoiler. Then use a press in threaded sleave in the main part of the spoiler. I will take lots of pics as it' getting done.
i wouldn't, just my . i would "glue" as suggested. if not made "perfect" it will be ...high/low......frank...
I think that when its done you won't be able to tell it was fixed. It will mount just like it originaly did.
