Can Trans Coolant Line Be Repaired.
Discussion in 'Technical' started by Tlowery643, Mar 31, 2014.
  1. Tlowery643
    Tlowery643 Member
    Rockmart, Georgia
    Got the new Mav running today and Trans Coolant Line has a hole in the line near the radiator. Just wanting to patch if possible as the 200 and trans are being replaced in a couple months. Is it possible or cheapest way to fix?
  2. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    Cut it and use good hose clamps and a piece of hydraulic hose or use a brass compression fitting. Ive used both ways on other vehicles
  3. Craig Selvey
    Just a small pinhole? Put a piece of rubber over it and clamp it.
  4. Acornridgeman
    Wisconsin
    Consider a repair temporary, just to keep you running until you can buy new lines. If it has started to leak in one area it will start leaking in others very shortly. New lines are easy to replace and cheaper than a tow if you get stranded somewhere. You can bend your own or buy pre-made ones from a place like Right Stuff Detailing.
    (y)
  5. Krazy Comet
    Unless they are rusty, most of the time they'll leak in a area where the two lines chafed on each other...
    Craig's bandage method is quick, easy & effective... Just split a piece of hose lengthwise(split away from leak) and clamp it in place...
  6. baddad457
    Get a 3-4" length of fuel hose and 4 hose clamps, cut the line at the leak, use the hose to bridge the gap, double clamps on each side of the gap. Problem solved.
  7. groberts101
    groberts101 Member
    Minneapolis, MN
    Yep... X2. (y)
    No offense intended to the others who mentioned it.. but just don't take the easy way out and split the hose instead of cutting the line at the leak. There's fairly substantial pressure involved here and a split hose patch will eventually leak. Trans fluid makes a mess of everything when it gets all over a motor and exhaust manifolds. ;)
  8. Krazy Comet
    I've yet to have a issue, even patched a EFI fuel pressure line using that method hadn't leaked in 5.5 years which was when I lost track of the car...
    Anyway he said something temporary...
  9. groberts101
    groberts101 Member
    Minneapolis, MN
    Sure.. I get the temp fix and al that. I didn't mean any disrespect with my wording.. and I might could have worded it differently though.
    So, just out of curiosity.. no smart assery involved:tiphat:.. how can a patch with a split down the opposite side of the hole prevent high pressure from forcing the fluid radially around the tubing and out the other split side? Do you put the clamp directly over the rubber line right above the hole itself?
  10. simple man
    simple man Member
    Bunnell,Florida
    Yep! Right over the hole. "KC" was talking about a relatively small hole I'm sure! I've used the "split hose" method on quite a few things in the past! Worked great on a rusted fuel line when I went to pick up a car in Nevada and drove it home to Florida! It stayed on there for quite awhile after that too, well at least till another rust hole appeared. The line was replaced then! :)
  11. groberts101
    groberts101 Member
    Minneapolis, MN
    ok.. got it and that's all I could figure on the reread. Unfortunately, me often writes quicker than me thinks sometimes. Read.. think.. read it again.. think some more.. THEN.. reply. :D
  12. Krazy Comet
    Yep place the "unsplit" side over the pin hole, use the clamp to hold the "hose bandage" over the hole...
    The one I did on the EFI fuel line had chaffed a "half pin hole"(for some time could smell, but not see a leak), in a area between the frame and body, was almost impossible to access... I've repl fuel lines on unibody EFI vehicle, would have been a total nightmare and a couple buckets of snakes on the full frame Grand Marquis...
