can you port an intake?
Discussion in 'Technical' started by JD71, May 25, 2008.
  1. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    im bidding on a factory intake on ebay, im geting it real cheap. the plan is to sand it down and paint it gloss black or somethin. i was just wondering if you can have an intake ported for better flow and about how much it would cost if it can be?
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    yup sure can...
    price varies on how much you want ported and where you take it...
  3. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    well that helps alot? i was afraid i was gonna be stuck with an old factory intake. about how much will it help to have it ported? if it dont cost too much ill have it ported as much as possible without messing anything up.
  4. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    porting prices vary.....just remember, cheaper is not always better.
  5. eddie1975
    Martinsburg, WV
    sold
    yup, and doing the whole intake isnt going to help to much with out heads being able to keep up with the flow
    what kinda intake is it?
  6. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    zackly....if your gonna do it, might as well have the heads/intake port matched. :thumbs2:
  7. rthomas771
  8. Mavman72
    Hard core racers will actually cut a manifold in half to get at all the ports/runners and so on.If you are running a fairly mild engine on the street you wont see much gain in porting an intake.If you plan to wind the wee out of it,then its worth the effort.Ditto for port matching.
  9. newtoford
    newtoford Member
    New Castle Delaware
    you can find good used aftermarket 4bbl aluminum intakes for 50-100 bucks, why waste time working with the factory stuff?
    if your after an actuall factory maverick 2bbl 302 intake i got one i can send you for the price of shipping. its a '77 intake
  10. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    Duh i forgot about that. i'll just have it matched to the heads if it needs it. its an old factory intake going on a 94 truck 302.
  11. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    Its a 4 bbl intake
  12. PaulS
    Yep! all that work and he got 8 more HP at 6300 rpm. and less HP at 5000rpm!!
    Buy a good intake - they are designed better and have larger ports - the design part is where the HP comes from, not the size.
