can you spot a problem?
Discussion in 'General Maverick/Comet' started by bigkat79, May 16, 2007.
  1. bigkat79
    bigkat79 Member
    indiana
    1976 maverick
  2. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    Hey bigkat what I would do is unhook the wires from the switch and short them out if the lights come on when you short them and are off when they are not shorted my guess is your switch is bad.
  3. bigkat79
    bigkat79 Member
    indiana
    1976 maverick
    you mean just run a wire to the two prongs or run a wire into both sides of the plug?
  4. stmanser
    Davenport, Iowa
    yes
    take the wires off the brake light switch... run a jumper wire from wire to wire.. have someone check the lights and see if they come on..
    if the lights come on.. the brake light switch is bad. if they do not come on, then you have a short somewhere, or the lights themeselves are bad
    dont leave that jumper wire in place too long.. you dont want to short the system out
  5. Dean Deeter
    Dean Deeter Member
    I do not remember how the switch is wired. But more than likley there is a plug that pulls off the switch. When you pull the plug off see if the lights go out. Then take a wire and short out the plug. By taking a wire and put into each side of the plug at the same time. If the lights come on when shorted I would say the switch is bad.
  6. bigkat79
    bigkat79 Member
    indiana
    1976 maverick
    thanks, i'll have to try it out tomorrow. no body around to help me out with it today.
  7. Dean Deeter
    Dean Deeter Member
    Hey bigkat, You can check by yourself un hook the switch and see if they go off.
  8. bigkat79
    bigkat79 Member
    indiana
    1976 maverick
    that's true, i'll do that. you guys are great, fast responses.
  9. bigkat79
    bigkat79 Member
    indiana
    1976 maverick
    well, i went back out to check them with the switch unplugged and before i even unplugged it they were out. couldnt get them to come back on. im suspecting the switch is bad. anyone have a part number for the switch?
  10. maverick1970
    maverick1970 MCG State Rep
    Missouri
    With Power Brakes
    Standard Ignition P/N SLS92
    AC Delco P/N F894
    Without Power Brakes
    Standard Ignition P/N SLS70
  11. bigkat79
    bigkat79 Member
    indiana
    1976 maverick
    cool, thanks. are the plugs available on the after market?
  12. 71gold
    you might want to check now and see if the bulbs are bad...if they have been on a while they may be blown :huh:
    ...:cool: ...
  13. bigkat79
    bigkat79 Member
    indiana
    1976 maverick
    i've been disconnecting the battery when i'm not messing with it.
  14. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    :banghead: Don't feel bad......I'm sure we have all done something like that :cry:
  15. stmanser
    Davenport, Iowa
    go to your local parts store.. they are very common
    and the plug goes on one way..
