can't bolt tranny up to engine?
Discussion in 'General Maverick/Comet' started by 98truck, Jan 13, 2008.
  1. 98truck
    98truck Member
    london Canada
    1970 Grabber Maverick
    I have a 1969 c4 tran (auto) and a 1988 5l HO engine that came out of a 5 speed standard mustang , when i go too bolt up the two the torque hit the center of the engine and thats stops me from putting the two together. Is there away of solving this problem.
    Thanks George
  2. Jamie Miles
    Are you sure the torque convert is seated down all the way? Sometimes you have to spin it around a little and screw with it a little to get it seated. Also, not sure if it matters, but did you remove the pilot bushing from the end of the crank?
  3. 19BlacK77
    19BlacK77 Member
    Make sure your torque converter is seated completly onto the transmission. If its not and you try to force it you WILL break something.
  4. 98truck
    98truck Member
    london Canada
    no i didn't remove the pilot bushing, should I ?
  5. Stews72s
    Stews72s Member
    N.C.
    1972 sprint maverick
    Straight Drive
    MANUAL TRANS REQUIRES REMOVAL:thumbs2:
    STEW
  6. stangclone
    stangclone Member
    ofallon,il
    1972 maverick,1965 mustang
    your converter is probley not in all the way and the bushing really don't need to be out it wont be in the way
  7. 98truck
    98truck Member
    london Canada
    is there anyway of putting on the flywheel on backwards cause when i put the converter upto the flywheel the center of the converter hit the engine and the studs will not go through the holes on the fly wheel
  8. 71gold
    might need to check and see if they gave you the correct...flexplate...:yup:
    is it the right converter? will the holes line up with the flexplate?
    what motor did the c4 come off of?...
    ...Frank...
  9. 98truck
    98truck Member
    london Canada
    the was a 69 302 before I replace with a 5L ho
  10. yellow75
    Tillamook Oregon
    As stated in Jamies reply you must take out pilot bushing from center of crank and the flexplate you will need will be a 50 oz weighted one instead of a 28 oz one like would be on the 69 c4, cant really put the flexplate on backwards as it would hit motor plate. Torque convertor should click three times to be all the way seated into transmission and back from face of bell housing about 1 1/8 inch. Dont try to force tranny into place or you will damage pump.
  11. stangclone
    stangclone Member
    ofallon,il
    yellow my pilot bushing is still in my crank and it has not caused any problems and I am running a c4 also :hmmm: Is that bad should I take it out? I left it in because I wasn't sure I was going to stay with a c4 our not and it didn't rub on anything :huh:
  12. don graham
    What is the torque convertor out of? Is it the original one that was in that transmission? 1969 was 24 spline input. After 1970 they went to a 26 spline. If it is the right one make sure you put the Convertor on the shaft and it should bump down t times as you spin it slowly on.
  13. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    Is the flexplate a 157 tooth or the 1988 164 tooth? 69 c4 would need a 157 tooth flexplate with a 50oz balance. I believe this is a non-stock aftermarket deal only.
  14. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Just a clarifying question.. you called it a flywheel... the motor is from a manual trans car.. you did replace the flywheel with a flexplate right? And no, you can't put them on backward and get all the holes to line up. Regarding the converter, if it's the one from the tranny, along with the bellhousing, this doesn't apply, but they are not all the same length. The converter for a large bell (164 tooth flexplate) is longer because the bell is slightly longer.
  15. yellow75
    Tillamook Oregon
    stangclone if you left the pilot bushing in and everything is still working then it must be okay or else you would have never got the torque convertor to seat far enough in, either that or you pulled flexplate back to convertor. I just did conversion from stick to auto and put my convertor up to my flexplate before trying to install tranny and the convertor would not seat against flexplate because of hub of convertor hitting pilot bearing, Maybe PaulS will chime in on this he is wise on these things
