Caprice Tailights
Discussion in 'Technical' started by lastchance, Jan 11, 2013.
  1. lastchance
    lastchance Member
    Hingham , Massachusetts
    How are you sealing the Caprice tailights to the rear body panel to keep water out of the trunk? Looking for ideas.
  2. 71gold
    I would think the seal that comes with the light bezel...(y)
  3. lastchance
    lastchance Member
    Bought the lights at a swap.No gaskets.Have been unable to find gaskets .No one seems to list them.Plenty of cars on here with Caprice lights,hoping someone will respond.
  4. car-nut
    car-nut Glenn
    conn.
    Strip caulk would work. Can be bought at any auto parts store.
  5. doncomfort
    chillicothe oh
    I have the gaskets from a set I used. I think I would have to cut way too much out to make them work. I don't remember. I used a quarter inch by quarter inch foam rubber to seal mine. You can have my set of gaskets if you want them. I have no use for them.
  6. mav1970
    You can buy new gaskets for the lenses to the housings but I don't believe they make the gaskets for the housing to the tail panel - I re-used the ones that came with my lights :)
  7. doncomfort
    chillicothe oh
    Thats what I have, light to panel gasket/ seal.
  8. lastchance
    lastchance Member
    Thanks for the offer doncomfort. I think i`ll try your foam idea. Thank you
  9. doncomfort
    chillicothe oh
    No problem. :Handshake
  10. baddad457
    :hmmm: Pictures would be worth a thousand words here. :huh:
  11. doncomfort
    chillicothe oh
    pics of seal
    Here are few pics of the seal and gaskets for the Caprice lights. The first is of the gasket and the back of the bezel. Unfortunatley the housing is installed in my car so I couldnt show the gasket in place. I don't think it's possible to use. Someone else might know more. The second pic is the foam rubber I used. The third is the lights on the car and the fourth is how I applied the seal.
  12. baddad457
    How about some pics with em installed on a Mav ?
  13. mav1970
  14. doncomfort
    chillicothe oh
  15. MSmithPDX
    MSmithPDX Member
    Portland, OR
    That foam rubber sticky backed stuff is really good when used as a sealant. You just have to be careful, if you tighten too hard you can cut clear through it with the parts you want to seal. I've used it in a lot of machine refurbishing for machines that are partially exposed to weather. Like machines that sit next to shipping bay doors, it rains a lot here after all. I wouldn't hesitate to use it on my car at all. The only issue I can see is that it breaks down to oils and fuels.
