caprice taillight mod
Discussion in 'Cosmetic' started by FIREBALL, Aug 5, 2014.
  1. FIREBALL
    FIREBALL Member
    1971 Ford Maverick Grabber
    Okay I'm sure it's been asked many times, but I'll do it again.....moderators if rhis n is the wrong forum feel free to move...
    I have two sets of taillights, a set of 69 Shelby lights and a set of 67 Caprice lights. To install the shelby lights properly I need to do some customizing on the taillight panel, but it appears the caprice lights can be more easily installed at least until I can get around to doing the shelby taillights this winter. What do I need to do to get the car home Caprice bezels to sit flat against the maverick taillight panel? They appear to want to sit out about 1/16" do to the factory casting. Also where can I get some light sockets for the caprice lights? Will 60's Ford push - in sockets work?
  2. yellow75
    Tillamook Oregon
    I have the Caprice taillights and they do stick out a little bit more than a 1/16", I could not figure away to get them to sit flush in the hole I know that mav1970 was working on this problem but have not heard if he ever found a solution. They do not look bad sticking out I simply put some clear caulking around them. As for the sockets yes the push in type will work.
    You will have to cut a slot in the taillight panel about 2 1/2" wide and about 4-5 inches long. When you do the mod you should get the sequential taillight sequencer and install it I get a lot of compliments about that mod
    FIREBALL likes this.
  3. FIREBALL
    FIREBALL Member
    Yes i plan on getting a digital sequencer......I love the look of the lights with the sequencer.
    yellow75 likes this.
  4. yellow75
    Tillamook Oregon
    When I did my conversion I ran a new power wire to the trunk area and added three relays it made the taillights brighter and did not have to worry about the extra load of 2 additional bulbs in the back and old wiring, not really needed but a nice touch, sorta like the headlight relay mod
  5. FIREBALL
    FIREBALL Member
    Mike do you have a diagram of your modification? Are you saying you built your own sequencer out of relays? If so I'd like to see a diagram.....I may do the same......
  6. yellow75
    Tillamook Oregon
    No I used the sequencer to operate the relays, I do have a diagram but havent figured away to post it on here. It is pretty simple to do if you understand normally open and normally closed contacts. I will see if I can get a copy made and post it up in the tech section and here
  7. doncomfort
    chillicothe oh
    I ran thin quarter inch thick foam rubber under the back of the bezel to fill and seal the small gap. I also have sequencers, love them,
  8. Wilbur Green
    Wilbur Green Member
    Plymouth, Ohio
    76Stallion, 762dr.
    Mike your taillights are awesome, relay bright when we followed at the Gathering.
  9. yellow75
    Tillamook Oregon
    I posted a very rough diagram of wiring needed to install relays in the tech section, I had a very nice drawn up one with straight lines but seem to have misplaced it
  10. FIREBALL
    FIREBALL Member
    I saw that, thanks! I'll probably refine it a little so that the relays only power up when the ignition is on.....great idea for brighter taillights!
    Thanks again brother.....
