Car not starting
Discussion in 'Technical' started by justin has a 74, Apr 1, 2011.
  1. justin has a 74
    kentucky
    Well im trying to get a 4 door 250 comet running (dang comets:D)
    sit in car, turn key, oil light comes on buzzer buzzes, nothing.....
    i can turn it over by using the 2 screw drivers method. I replaced the ignition switch, starter solinoid, looked around for some type of hacking and came up with the seatbelt box (yellow box) The sensor wires have been previously cut so i did the box removal steps. I still have the underhood button.:(
    Alt wires are off.
    Any ideas would be appreciated:thumbs2:
  2. justin has a 74
    kentucky
    car has points. im going to go remove the little red button under the hood.
  3. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    12 volt to S term on Solenoid during starting position?
    Good ground on solenoid?
    Neutral safety switch?
  4. rthomas771
    Found your problem. Electricity not making a compete circuit...hook the wires back to the alternator
  5. chevyandford71
    chevyandford71 Member
    Apex, NC
    1971 Ford Maverick Grabber, 1991 Honda CRX HF w/B18A1 swap, 2001 Honda CR80R
    i remember when my 250 did this to me.....in myrtle beach at 12AM
  6. justin has a 74
    kentucky
    weird:hmmm:
  7. justin has a 74
    kentucky
    button removed and heard the car run will try the alt. monday or friday
  8. justin has a 74
    kentucky
    alt hooked up. No start.
    turn key and temp light comes on, oil light comes on and brake light comes on. I found a blue, orange and red wire in a clip hanging down. THe clip looks like a face |_| Any ideas? will try to see if power to s terminal and change neutral safety switch.
  9. justin has a 74
    kentucky
    no radio, no lights, no horn, nothing
  10. justin has a 74
    kentucky
    Dome light comes on until i turn the key, then it goes off. Getting power to s and i terminal when key is on.
  11. cactusgrabber
    cactusgrabber Member
    Tempe, Arizona
    72 Grabber
    Just trying to help ya....I have to leave for awhile...but will check back later...in the meantime try this stuff:
    I posted a schematic for you below.
    Make sure everything that should be grounded is.
    The "s" should only have power when the key is in the start position.
    The "I" is explained below...and will have power in both the run position, and the start position, for different reasons, when it is working properly.
    There are TWO SEPARATE CONTACTS THAT CLOSE in the solenoid, when cranking the keyswitch/starter in the "Start" position:
    1. The MAIN contact closes (the large terminals on the solenoid) which connect the battery's positive voltage to the starter.
    2. The smaller "coil boost" contact closes in the solenoid, connecting the battery positve to the "I" terminal, which leads to the coil's primary, and is for applying extra power to the coil during starting.
    Make sure your ignition wiring is like this:
  12. cactusgrabber
    Tempe, Arizona
    72 Grabber
    Any progress on your car starting?
  13. justin has a 74
    kentucky
    unfortunately no. I do not think my removal of the button under the hood was correct. PEople have mentioned something on the subject but did not make 100% clear of their actions. i will check again
    http://mmb.maverick.to/showthread.php?t=67416&highlight=button+hood
    I have done this and confirmbed that the red blue wire has power. so does one of the other red blue wires.
  14. justin has a 74
    kentucky
    any idea what the white wire leads to?
  15. cactusgrabber
    Tempe, Arizona
    72 Grabber
    Can you be more specific please? There is more than one wire in the schematic that has white as the main color.
    None that I saw listed as just white, but I could be wrong, I scanned it quick, and I'm getting ready to go see a movie....be back later.
