Car tries to start when I hook up the battery
Discussion in 'Technical' started by Jason M, Jul 31, 2011.
  1. Jason M
    Jason M Hibernatin for the Winter
    Wingham, Ontario
    1976 Ford Maverick
    Ok so the Mav is normally my daily driver during the summer but I have been on holidays for the last week so I had been away. I went to use the car yesterday and it wouldn't turn over.
    Took the battery out to charge it, so when I went to put it back in the car started up ran for about a minute then stalled. Tried starting it a few more times then it wouldn't crank at all, not even that annoying sound from the door buzzer.
    Charged the battery again but this time when I went to put the battery in the minute I went to hook up the postive cable the post arc'd and the car tried to start without the key in the ignition.
    So do you guys think the starter is gone? Cable from the starter to the solenoid? Solenoid itself (although it was replaced last summer)?
    Any thoughts ideas would be appriecated
  2. spork1o1
    spork1o1 Member
    Michigan
    sounds like the solenoid on the inner fender is stuck.
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Pull the trigger wire off the solenoid and see if it continues. If it does it's the solenoid, if not it's a short somewhere giving power to the solenoid.
  4. tomboy
    tomboy Member
    Could be a bad ign switch.
  5. DC12VOLT
    DC12VOLT Fuel Injected
    Everett, WA
    Cream 1971 Maverick
    That's happened to me a couple times, every time it was the solenoid. I'd give it a light tap with a hammer and that usually fixes it.
  6. darren
    Do you have any power to the rest of the car? Hows the connections at the batt to solenoid etc. Could be a bad cable causing low voltage. Also is the batt any good? Did you test it? Low voltage will stick the solenoid.
  7. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    I'd buy a new solenoid and try that first. In fact, I'd buy two. They seem to commit suicide at an alarming rate.
  8. jdproper37
    jdproper37 Member
    Fargo, ND
    1977 Ford Maverick 4dr
    LOL :rofl2:That is very true
  9. Centerline
    Centerline Member
    Washington State
    1971 Ford Maverick Grabber
    After trying to turn over the car with no results you can end up burning up your solenoid. That's happened to me, which is why I bought two last time and carry the spare in the trunk . . .
