Car won't start
Discussion in 'Technical' started by russellgaspard, Aug 5, 2014.
  1. russellgaspard
    russellgaspard Member
    united states
    1973 Ford Maverick 250 Inline 6
    I finished getting everything back together on my maverick and it tries to turn over but won't start. It putts a couple of times and then dies. I set the the distributor at #1 and TDC at 0*. I'm not sure why it still isn't starting. Can anyone tell me what the problem might be?
  2. mojo
    have u checked to see if your getting fire/spark to the plugs? getting fuel squirted from carb? lastly got firing order correct?
  3. russellgaspard
    united states
    I checked the spark and its good. Its getting fuel to the carb and I checked the firing order. They are all good.
  4. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    If it backfires through the carb you may have the distributor 180 deg out.
  5. russellgaspard
    united states
    How do I check if the distributor is 180 degrees out?
  6. Maverocket
    Northwest
    There are a couple ways to find out. You can pull the valve cover and rotate the engine while watching the #1 intake rocker arm. When the intake valve closes and the timing mark comes up to TDC the rotor should point to the #1 cyl on the cap. If its on the other side of the cap it's 180 degrees off so pull the dizzy and align the rotor to the #1 position. The other way is to just skip checking valve action and rotate the dizzy shaft 180 and see if it fires. If the problem gets worse you probably had it right the first time.
  7. russellgaspard
    united states
    Oh. Well earlier today I set the timing mark to TDC and then set the distributor to the #1 cyl on the cap so thats not the problem. :/
  8. Maverocket
    Northwest
    Did you get TDC on the compression stroke or exhaust stroke. There are 2 TDC events in one cylinder cycle.
  9. russellgaspard
    united states
    Hmm that im unsure of. How can I tell?
  10. Maverocket
    Northwest
    Follow what I said in the previous post.
  11. russellgaspard
    united states
    So the number one rocker arm, will it be up or down?
  12. russellgaspard
    united states
    Also wouldn't another way of fixing it without taking off the valve cover be to rotate the distributor 180 degrees?
  13. Maverocket
    Northwest
    As the intake rocker comes back up while rotating, watch for TDC to come up on the balancer. And yes, you can just rotate the dizzy and see if it works. That is the second way I suggested.
  14. 71gold
    pull the #1 plug, rotate the engine with your finger over the plug hole (not in it) until you feel the compression pushing your finger off the hole. then bring it on up to TDC on the timing mark...just did this yesterday.
  15. russellgaspard
    united states
    I pulled the #1 plug and rotated the engine like you said to do and the distributor was set correctly. So the timing is correct. Maybe something else thats keeping it from starting? I just cleaned the spark plugs
