Car won't start
Discussion in 'Technical' started by 1MTMIND, Dec 26, 2015.
  1. 1MTMIND
    1MTMIND Member
    California
    73 Maverick/Comet
    just did a full brake rebuild front and back and thing we're good for about 4-5 days. Car just turns over and over now but won't fire. Replaced my coil and no change. It's getting fuel and the pressure is good. I'm unable to think straight due to issues with my other vehicle at the same time. Any help is greatly appreciated. Thanx
  2. Mavman72
    Check for spark While cranking engine (A nice bright blue one) At coil and at plug(In that order) Report back what you find...
  3. 1MTMIND
    1MTMIND Member
    California
    73 Maverick/Comet
    Spark was very weak with original coil (MSD Blaster SS). Very weak spark from plug wire. Bought new coil (same) and it has good bright spark. Still weak spark from plug wire though. Brand new battery. MSD pro billet ready to run distributor. I've never had an issue starting my car since I've owned it for over 15 yrs.
  4. Krazy Comet
    If spark is good at coil and not at plug wire(s), the cap, rotor and/or wires are bad...
    Dave B and Ronald Hopkins like this.
  5. 1MTMIND
    1MTMIND Member
    California
    73 Maverick/Comet
    I had a lose and corroded wire going from the positive on the battery to the starter solenoid. Bought a new one today and installed it. It fired right up. Should run better now too with a new coil and good constant power to everything.
  6. 71gold
