Car won't start
Discussion in 'Technical' started by 98truck, Jan 1, 2010.
  1. 98truck
    98truck Member
    london Canada
    1970 Grabber Maverick
    i REBUILD CAR FROM GROUND UP AND NOW SHE WON'T START? It' has fuel & gas, it's top dead center and rotor is line up with # 1 plug.
    I put protronix dist in it. She turns over but no start. It doen't even try to start.
    Please help
    George
      File size:
      359.3 KB
      24
  2. Dave B
    Do I have to come over?
  3. 98truck
    98truck Member
    london Canada
    that won't be nice:)
  4. Dave B
    Are you worried something else will quit.....:rolleyes: Your car is shy around me.
  5. 98truck
    98truck Member
    london Canada
    call me 519 649 1640
  6. Dave B
    I have to find a phone...
  7. Jeff S
    Jeff S Member
    NoVA
    none
    Does it have a full body-engine-chassis grounding system?
    Very nice car :D
  8. 98truck
    98truck Member
    london Canada
    there is fuel and spark just wont ignite the fuel tested all cylinders and there is spark at all cylinders
  9. Jeff S
    Jeff S Member
    NoVA
    none
    Hows the compression?
  10. Dave B
    It's the choke, I'm sure of it! :rolleyes:
  11. Jamie Miles
    Alto, GA
    I've had a few
    Sounds like it's a piece of junk. I'll come and take it off your hands, so you won't have to mess with hauling it to the scrap yard. :D
    If you've got fuel and spark, it should at least do SOMETHING. Is it spitting out the carb any? Have you checked that fuel is actually in the carb, and squirting out when you open the throttle up?
  12. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    72 mav grabber(sold), 1970 maverick grabber clone
    hmm do i what i do put the choke all the way down and have a battery charger hooked up to your battery and it should fire right up
  13. 98truck
    98truck Member
    london Canada
    not sure dont have a compression tool but ran fine when taken out 3 years ago out of a 5.0 mustang
  14. yellow75
    Tillamook Oregon
    Are you sure the distributor is not 180 degrees out?
  15. Dave B
    It's gotta be something goofy, he's tried everything. We'll see if we can get it figured out one night this week.
