Carb Fire!
Discussion in 'Technical' started by midwest-mav, Apr 12, 2005.
  1. midwest-mav
    midwest-mav Member
    Topeka, Ks.
    73 Maverick, 98 Dodge Ram 4x4, 85 Jeep CJ7, 58 Ranch Wagon
    84 351, This is a truck we are working on. If we can get it running we will recieve in trade another truck with bad motor, good manual trans, I have another good 302,auto from a rollover, as donor. One good truck, and maybe a good manual trans for one of my mavs.
    Owner says truck sat for a couple years. Tried to start, wouldnt. He Rebuilt carb tried to start, caught fire! We replaced melted throttle cable, pulled carb,and rebuilt. We noticed when we did rebuild he had a few parts missing that we used from our kit. Bench set floats then strayed stupid. Installed carb while butt end of truck still up on tow dolly. Started truck, ran!, but rough. It was dumping fuel. Leveled truck, Adjusted floats. Checked oil, You allready know it was full of gas. Changed oil. Tried to start. Backfire, Carbfire.
    Triple checked plug and wire firing order, still correct. Did compression test, looked real good. Cap and rotor recent and look good.
    Whats next? Thanks!
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Are you sure it hasn't jumped time.
    Also make sure you are using the correct firing order for a 351?
